12-09-2020 09:51 AM
I am attempting to update to the new CollectorVersion 2.9.0 from 2.8.1.8. The ssh level admin, collectorlogin and root passwords were requiring reset under 2.8.1.8 when I went to start the backup/migration script part of the upgrade. I logged into admin, resetting the password and did a pwdreset collectorlogin 90, followed by a pwdreset root 90 to get new passwords as these accounts are needed for the upgrade.
When I log in as collector login and then issue a "sudo root" or "sudo -" I don't get the root password prompt. It is instead
[sudo] password for collectorlogin:
If I enter the root password here, it gives me "Sorry, try again." If I enter the collectorlogin password, it completes with "collectorlogin is not in the sudoers file. This incident will be reported."
I have restarted the collector server several times and reset the root and collector login passwords twice now.
Any insights into what is happening or how to rectify. I am also opening a case with Cisco TAC.
Solved! Go to Solution.
12-09-2020 10:31 AM - edited 12-09-2020 10:31 AM
once you connect via ssh with the user collectorlogin the correct command to switch to user root is -->
$ su root
let me know if that works for you
$ su root
12-09-2020 01:50 PM
Hi Andre,
Thanks for the quick response. That command works.
I had upgraded another collector to 2.9 last week and sudo - was giving me just a password prompt that took me to root on that system. Moving on to this other one I expected the same behavior. I will update my notes to use the su root going forward.
Thanks - Bill
