Common Service Platform Collector
Mori2018
Which of these do I install? or both?
Collector patch to upgrade to CSPC 2.7.4
collector_2.7.4_Build-103.zip
03-MAY-2018
1059.36 MB
Network size dependent on Collector image (New Install)
Collector-2.7.4-B-36.ova
Supriya Patel
Collector-2.7.4-B-36.ova - this one is for brand new install
Supriya
Supriya Patel
Supriya
Thanks, when would the patch(other file) be needed?
collector_2.7.4_Build-103.zip would be needed to perform a manual upgrade into version 2.7.4, assuming you are coming from a 2.7.x version that is < 2.7.4.
More details here: https://www.cisco.com/c/dam/en/us/support/docs/cloud-systems-management/common-services-platform-collector-cspc/CSPC-Manual-Upgrade-Guide.pdf
Regards.
