Connectivity Service is Not Running
Smartnet
Hello everyone, below I am producing an error in regards to the Connectivity Service between the portal and the Collector.
Could I get assistance on troubleshooting as to why we're receiving this error? Thank you.ConnectiVityService.png
jofrumki
Can you please run these commands from the CLI while logged in as root and share the output in a private message;
telnet 72.163.7.113 443
curl --tlsv1.2 https://72.163.7.113/HeadEndWebAppServlet/ -v
cat /opt/ConcsoTgw/tail-end-gateway-decoupled/conf/csof_config.xml
Can you please advise if there was a fix for this issue? - we are experiencing the same error on a number of CSPC's
