Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
293
Beginner
CSCP 3.7 -> 3.7.4 upgrade loop
I started the upgrade of CSCP 3.7 -> 3.7.4 via GUI and it got stuck. So I did some research on internet, and found a way to start it manually via lcmagent-apply.tcl here:
https://supportforums.cisco.com/t5/smart-net-total-care-portal-and/update-to-2-7-stuck-at-apply-in-progress/td-p/3034924
That was probably not a good idea because now the upgrade is in loop. It runs for aprox. 2 hours, succeeds and restarts the server, only to find out it is somehow still running 3.7 and starting the upgrade again. I am attaching the latest Install and Apply logs.
Everyone's tags (1)
1 REPLY 1
Highlighted
Re: CSCP 3.7 -> 3.7.4 upgrade loop
Can you attempt to manually reboot the server as well as provide the commands you submitted to manually initiate the patch installation via CLI?
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
