11-20-2019 05:50 AM
The message below is displayed everytime I try to upload my devices on CSP.
We gave all permissions to the server on firewall though it wasn't enough.
A connectivity exception occured while processing the request. The Exception is :: HTTPs TransportMode has Failed 400:Bad Request
11-20-2019 06:44 AM
From our logs it indicates that the upload you sent on 11/20/19 shows that no devices were uploaded. Please confirm you are running the default SNTC collection profile which should upload your devices when the collection has completed automatically. If you have a scheduled upload profile please disable this as it could corrupt the data on SNTC.
11-20-2019 06:46 AM
what is the version of CSPC ?
Please run below commands from the command line as collectorlogin or root
curl --tlsv1.2 https://concsoweb-prd.cisco.com/HeadEndWebAppServlet/ -v -k
wget https://concsoweb-prd.cisco.com/HeadEndWebAppServlet/ --no-check-certificate
Please check if TEG is running
# service concsotgw status
You can try restarting as well.
# cspc restart
11-20-2019 09:26 AM
Thank you Balaji. Those are good steps if we were trying to check in the dark.. Not in this specific case where the error is very specific. The error TransportMode has failed : 400 bad request is very specific and is associated with a certificate not collecting the data, not necessarily an upload access problem, I will need additional output to review the problem. as Joshua mentioned very likely related to a Collection Profile not running properly or a rogue certificate in the database.
VERACEL TEAM. Por favor me mande EM PRIVATE sequinte.
In deploying the image you would have created the cli admin password? (java based shell)
If so have you also created/activated the users collectorlogin and root ? (real linux shell)
If not do the following for the cli admin shell
admin# pwdreset root 90
And
admin# pwdreset collectorlogin 90
it will activate those accounts and generate their passwords ( keep them where you can refer to them in the future)
after that
Via SSH Login to collector as user collectorlogin and then use command below to connect as root (cannot connect directly)
# su root
and then execute the following commands :
Please send me the output in Private message
# tail -100 /opt/ConcsoTgw/tail-end-gateway-decoupled/bin/CONN_TEG_LOGS/tail-end-gateway.log
# openssl s_client -showcerts -connect concsoweb-prd.cisco.com:443
# tail -100 /opt/ConcsoTgw/tail-end-gateway-decoupled/bin/nohup.out
# wget https://72.163.7.113/HeadEndWebAppServlet/ --no-check-certificate
Also send me the following screenshot from your web collector application
