09-23-2015 12:01 PM
So looking through all of the questions for setting up a collector the response is "wait for 2.5". I have tried to get TAC support to setup 2.4 but they just referred me to these forums, which tells me to wait for 2.5.
My question then is when is 2.5 coming out?
Solved! Go to Solution.
09-23-2015 12:38 PM
2.5 is currently anticipated to come out sometime in the next week or two.
Thank you,
Lynden
10-09-2015 07:00 AM
It has just been released, check here: https://software.cisco.com/download/type.html?mdfid=283107976&catid=null
Chris
09-23-2015 12:38 PM
Thank you,
Lynden
09-23-2015 12:39 PM
Thank you Lynden
09-24-2015 02:04 PM
Is this it:
http://www.cisco.com/c/dam/en/us/td/docs/net_mgmt/smart_portal/Common_Services_Platform_Collector_Quick_Start_Guide.pdf
https://software.cisco.com/download/release.html?mdfid=283114009&softwareid=283308676&release=Collector%20Server&relind=AVAILABLE&rellifecycle=&reltype=latest
09-24-2015 02:39 PM
No, that's something different. Once the release is made it will appear here under Smart Net Total Care:
Lynden
10-14-2015 01:38 PM
That link is for 3.x.
Another thread states 2.5.
Which should we recommend to end users/customers?
10-14-2015 01:41 PM
It's the same thing. SNTC 3.x uses the CSPC 2.5 collector appliance that you can download at that link.
Lynden
10-14-2015 02:11 PM
Hi kyletorkelson1,
The version numbers are a bit confusing, but let me clarify:
3.x is the version of the SNTC web portal (tools.cisco.com/smartservices)
2.5 is the version of the latest collector software (CSPC - collector software)
Due to the close numbering this might cause some confusion, but just keep in mind the differences. The collector's newest version is 2.5, therefore that is what's recommended for use with the 3.x SNTC portal.
10-09-2015 06:45 AM
Hi Lynden,
What is the current status of the 2.5 release?
10-09-2015 07:00 AM
Chris
10-09-2015 07:09 AM
Thanks, Downloading it now.
