CSPC 2.5?
collinsja
So looking through all of the questions for setting up a collector the response is "wait for 2.5".   I have tried to get TAC support to setup 2.4 but they just referred me to these forums, which tells me to wait for 2.5.
My question then is when is 2.5 coming out?
2 Accepted Solutions
Lynden Price
2.5 is currently anticipated to come out sometime in the next week or two.
Thank you,
Lynden
It has just been released, check here: https://software.cisco.com/download/type.html?mdfid=283107976&catid=null
Chris
10 Replies 10
Lynden Price
Thank you,
Lynden
Thank you Lynden
Is this it:
http://www.cisco.com/c/dam/en/us/td/docs/net_mgmt/smart_portal/Common_Services_Platform_Collector_Quick_Start_Guide.pdf
https://software.cisco.com/download/release.html?mdfid=283114009&softwareid=283308676&release=Collector%20Server&relind=AVAILABLE&rellifecycle=&reltype=latest
No, that's something different. Once the release is made it will appear here under Smart Net Total Care:
Lynden
That link is for 3.x.
Another thread states 2.5.
Which should we recommend to end users/customers?
It's the same thing. SNTC 3.x uses the CSPC 2.5 collector appliance that you can download at that link.
Lynden
Hi kyletorkelson1,
The version numbers are a bit confusing, but let me clarify:
3.x is the version of the SNTC web portal (tools.cisco.com/smartservices)
2.5 is the version of the latest collector software (CSPC - collector software)
Due to the close numbering this might cause some confusion, but just keep in mind the differences. The collector's newest version is 2.5, therefore that is what's recommended for use with the 3.x SNTC portal.
Hi Lynden,
What is the current status of the 2.5 release?
Chris
Thanks, Downloading it now.
