Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
1272
mygwl
Beginner
CSPC 2.7.4 Gui Upgrade to 2.7.4.2
Dear Support Community,
I'm trying to upgrade my collector via the GUI.
The Software Update tab is telling me that there is an available update. See screenshot below.
When I do click on 'Upgrade now', nothings happens.
The Upgrade manual says that I have to accept some kind of " K9 EULA".
There is no EULA or agreement displayed to me by the system.
I checked via the command shell, no success either.
I did rebooted the appliance, nothings change.
Any clue why the update is not working ?
Thanks in advance,
M.
1 ACCEPTED SOLUTION
Hi there MJ.
I think that the PDF is messing up the formatting.
The command is meant to be a single line command.
/bin/sh /opt/LCM/bin/sqliteToDerbyScripts_shell.sh "connect 'jdbc:derby://localhost:1527/opt/LCM/info/updates; create=true;user=app;password=password';" "update updates set PACKAGE_STATUS = 'Apply-failed' where PACKAGE_STATUS = 'Apply-in-progress';"
Try to run this as a single command and report back.
14 REPLIES 14
Supriya Patel
Hi User,
Could you please try upgrade via adminshell? Please do let me know if you  need any information on that.
Supriya
I have the exact same issue.  Here are the results from the adminshell:
admin# upgrade
Version Description
sp-30.0.4-2-0-lnx64 Collector patch to upgrade to CSPC 2.7.4.2
Download and apply of a package can take a while.
It is recommended to schedule the upgrade.
Do you want to continue [y|n] ?y
Please enter the version to upgrade :sp-30.0.4-2-0-lnx64
Do you want to continue with download and apply [y|n] ?y
Connection to Software Download Server will use User Id 'mjourney'.
In order to download software, please indicate that you have read and agree
to be bound by the Cisco End User License Agreement which can be viewed at
http://www.cisco.com/en/US/docs/general/warranty/English/EU1KEN_.html
Accept License Agreement (y|n)? y
Attempting to download the requested package.....sp-30.0.4-2-0-lnx64
execute % Error occured while executing command
admin#
My firewall logs show the appliance successfully connecting to 72.163.7.113/443 and transferring 6K bytes, then receiving a TCP FIN.
Please advise.
MJ
Thank you for your post. For fastest assistance, we ask that you start a new discussion. Our experts want to handle individual community member's post separately.
Here is the output of the command upgrade :
                Cisco Network Appliance Administration
To see the list of all the commands press '?'
admin#
admin# upgrade
Version            Description
Connection to Software Download Server will use User Id 'MYUSERID'.
We didn't recognize the username or password you entered. Please try again.
File could not be located on the server.
Please contact the release team.
admin#
Then I checked the upgrade manual, and followed the procedure using collectorlogin :
Last login: Tue Jun 19 14:15:56 2018 from x.x.x.x
#     This system is hardened and for the use of authorized users only. #
#     Individuals using this computer system without authority, or in   #
#     excess of their authority, are subject to having all of their     #
#     activities on this system monitored and recorded by system        #
#     personnel.                                                        #
#     In the course of monitoring individuals improperly using this     #
#     system, or in the course of system maintenance, the activities    #
#     of authorized users may also be monitored.                        #
#     Anyone using this system expressly consents to such monitoring    #
#     and is advised that if such monitoring reveals possible           #
#     evidence of criminal activity, system personnel may provide the   #
#     evidence of such monitoring to law enforcement officials.         #
[collectorlogin@pr-cspc-s01 ~]$ su -
Password:
Warning: your password will expire in 47 days
[root@pr-cspc-s01 ~]# su admin
admin# download sp-30.0.4-2-0-lnx64 -> I guess this is the latest version ?
Authentication failed. Please re-enter your CCO login credentials.
    CCO Id  : MYUSERID
    Password  :
In order to download software, Please confirm that you have read
and agree to be bound by the terms which can be viewed at
https://software.cisco.com/download/eula.html
Download of package has been initated.
Since that time it's stuck on Download of package has been initiated...
Is it normal that the download is taking so long ?
If I check the download status thru a second ssh session, I got no  information about the supposed ongoing download :
admin# show download *
admin# show download [version|-c|progress]
Eg:
admin# show download -c
admin# show download progress
admin# show download sp-1.11.1-2-0-lnx64
admin# show download jeos-1.11.1-2-0-lnx64
admin# show download progress sp-1.11.1-2-0-lnx64
where '-c' option displays the successfully downloaded packages
Download information is not available.
Package Name            Package Status        Completed at
sp-30.0.4-0-0-lnx64        Downloaded        May/09/2018 14:30:02 -> this is the previous package who was successfully applied via GUI early May.
I did checked my firewall logs and I do see allowed traffic between the Collector and Cisco's download websites.
Nothing is dropped.
Looking forward to hearing from You.
Thanks in advance, M.
Since it appears that the last download attempt was initiated (but Adminshell cannot confirm) could you also provide the output of the below command as 'collectorlogin'?
ls -larths /opt/LCM/tmp
Download was finally completed, see the output of the show download -c command :
sp-30.0.4-2-0-lnx64        Downloaded        Jun/21/2018 13:15:48
admin# show apply
    Version Number     : sp-30.0.4-0-0-lnx64
    Status             : Applied
    Start Time         : May/09/2018 14:30:27
    End Time           : May/09/2018 15:12:59
    Version Number     : sp-30.0.4-2-0-lnx64
    Status             : Apply-in-progress
    Start Time         : Jun/21/2018 15:48:43
    End Time           : -
The apply process is running for two hours now.
Thanks for confirming.
You can also monitor the status via the below CLI command:
tail -f /opt/LCM/logs/apply
Specifically, there should be a line containing the phrase 'status db updation completed'
Dear Support,
Here is the output of tail -f /opt/LCM/logs/apply  :
[collectorlogin@pr-cspc-s01 ~]$ tail -f /opt/LCM/logs/apply
[Thu Jun 21 15:57:49 CEST 2018] else block of status update
[Thu Jun 21 15:57:49 CEST 2018] update version--1.7.1--
[Thu Jun 21 15:57:49 CEST 2018] --Component--Hardened CentOS--Hardened CentOS |Component |JeOS |6.8 patch#0 |Hardened CentOS |1525870335--jeos-30.0.4-0-lnx64--
[Thu Jun 21 15:57:49 CEST 2018] update version--6.8 patch#0--
[Thu Jun 21 15:57:50 CEST 2018] --JeOS--JeOS--JeOS |JeOS | |jeos-30.0.4-2-lnx64 |Appliance Base Package patch update |1525870335--jeos-30.0.4-0-lnx64--
[Thu Jun 21 15:57:50 CEST 2018] else block of status update
[Thu Jun 21 15:57:50 CEST 2018] update version--jeos-30.0.4-2-lnx64--
[Thu Jun 21 15:57:50 CEST 2018] status db updation completed
inside
On the GUI, the status is still stuck on "Apply-in-progress"
Output of show version :
admin# show version
    Build-name   : Collection Platform Software 2.7.4
    Version      : sp-30.0.4-0-0-lnx64
Ouput of show apply :
admin# show apply
    Status             : Applied
    End Time           : -
It's running for 4 days now. Should I try to reboot the virtual appliance ?
Hello.
This appears to be the same issue we had in some previous versions.
Please try the workardound detailed in the "Known Issues" section in this document (bug CSCvi28525) :
https://www.cisco.com/c/dam/en/us/support/docs/cloud-systems-management/common-services-platform-collector-cspc/CSPC-ReleaseNotes-2732.pdf
This too is failing.  I'm not knowledgeable enough with Linux/Bash to parse out what I'm doing wrong or what is wrong with the command(s).
I copied and pasted the "command" in the article verbatim.  I did look for the "/opt/LCM/info/updates" directory and it *does* exist.
[root@scspsgamprod01 collectorlogin]# /bin/sh
sh-4.1# /opt/LCM/bin/sqliteToDerbyScripts_shell.sh
sh-4.1# "connect
sh: connect
; create=true;user=app;password=password';: No such file or directory
sh-4.1# "update updates set PACKAGE_STATUS = 'Applyfailed'
> where PACKAGE_STATUS = 'Apply-inprogress';"
sh: update updates set PACKAGE_STATUS = 'Applyfailed'
where PACKAGE_STATUS = 'Apply-inprogress';: command not found
sh-4.1#
Thanks!
MJ
Hi there MJ.
The fix seems to take properly now but the download still fails because the CSPC is still attempting to contact my firewall instead of direct to the internet via the firewall (see output below). Here is the output of the derby command: [root@scspsgamprod01 collectorlogin]# /bin/sh /opt/LCM/bin/sqliteToDerbyScripts_shell.sh "connect 'jdbc:derby://localhost:1527/opt/LCM/info/updates; create=true;user=app;password=password';" "update updates set PACKAGE_STATUS = 'Apply-failed' where PACKAGE_STATUS = 'Apply-in-progress';" [root@scspsgamprod01 collectorlogin]# [root@scspsgamprod01 collectorlogin]# And the result of the check update and download commands: admin# check update Patch versions ------------------------------------------------------ Version Number: sp-30.0.4-2-0-lnx64 Description: Collector patch to upgrade to CSPC 2.7.4.2 Required Versions: sp-30.0.4-0-0-lnx64 Optimal JeOS: jeos-30.0.4-2-lnx64 Reboot Needed: Yes Restart Needed: Yes Package Size: 108932255 bytes Contents: Component Name: Rules Pack Version: 4.6 Description: 4.6 Component Name: CSPC Base Version: 2.7.4.2 Description: CSPC 2.7.4.2 Installable: Yes admin# download sp-30.0.4-2-0-lnx64 execute % Error occured while executing command admin# The packet trace showing the CSPC communicating with the proxy: 15099.766019 10.200.28.100 -> 10.100.16.30 TCP 45892 > webcache [SYN] Seq=0 Win=14600 Len=0 MSS=1460 SACK_PERM=1 WS=7 15099.788005 10.100.16.30 -> 10.200.28.100 TCP webcache > 45892 [SYN, ACK] Seq=0 Ack=1 Win=14600 Len=0 MSS=1360 SACK_PERM=1 WS=7 15099.788005 10.100.16.30 -> 10.200.28.100 TCP webcache > 45892 [SYN, ACK] Seq=0 Ack=1 Win=14600 Len=0 MSS=1360 SACK_PERM=1 WS=7 15099.788005 10.200.28.100 -> 10.100.16.30 TCP 45892 > webcache [ACK] Seq=1 Ack=1 Win=14720 Len=0 15099.788005 10.200.28.100 -> 10.100.16.30 HTTP CONNECT concsoweb-prd.cisco.com:443 HTTP/1.1 15099.812006 10.100.16.30 -> 10.200.28.100 TCP webcache > 45892 [ACK] Seq=1 Ack=200 Win=15744 Len=0 15099.812006 10.100.16.30 -> 10.200.28.100 TCP [TCP Dup ACK 1472#1] webcache > 45892 [ACK] Seq=1 Ack=200 Win=15744 Len=0 15099.901006 10.100.16.30 -> 10.200.28.100 HTTP HTTP/1.1 407 Proxy Authorization Required (text/html) 15099.901006 10.100.16.30 -> 10.200.28.100 HTTP [TCP Out-Of-Order] HTTP/1.1 407 Proxy Authorization Required (text/html) 15099.901006 10.200.28.100 -> 10.100.16.30 TCP 45892 > webcache [ACK] Seq=200 Ack=959 Win=16640 Len=0 15099.912007 10.200.28.100 -> 10.100.16.30 TCP 45892 > webcache [FIN, ACK] Seq=200 Ack=959 Win=16640 Len=0 15099.942004 10.100.16.30 -> 10.200.28.100 TCP webcache > 45892 [FIN, ACK] Seq=959 Ack=201 Win=15744 Len=0 15099.942996 10.100.16.30 -> 10.200.28.100 TCP webcache > 45892 [FIN, ACK] Seq=959 Ack=201 Win=15744 Len=0 15099.942996 10.200.28.100 -> 10.100.16.30 TCP 45892 > webcache [ACK] Seq=201 Ack=960 Win=16640 Len=0 Thanks! MJ
Dear Support,
I have applied the fix and restarted the apply patch process.
I will keep you posted.
The fix proposed above solved the issue
 And here is the command line output.
admin# show apply
    Status             : Applied
    Status             : Applied
    Start Time         : Jun/25/2018 22:56:35
    End Time           : -
Thanks everybody for the support.
Regards, M
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
