06-30-2017 09:01 AM
I am trying to complete the Initial Install via Browser however it keeps saying failure:
✗ Timezone configuration failed to execute |
✗ NTP Server configuration failed to execute null |
✗ DNS address configuration failed to execute, null |
✗ Hostname configuration failed |
? Proxy server configuration was not provided |
Solved! Go to Solution.
07-07-2017 09:30 AM
Hello There,
Glad to hear that re-powering the VM helped solve your issue. For the next step, once you have access set up to the SNTC Portal, you can login and generate a CSPC certificate to import into your collector.
A detailed document on generating a certificate is available here.
Thank you,
Jarrett
06-30-2017 04:05 PM
Can you please login as root user and run the command "service adminshell restart" to see if this helps to resolve your issues? After the command is done, you can try to complete the wizard steps again.
Thank you,
Jarrett
07-07-2017 12:17 AM
Hi Jarret
Following confusion on my behalf about which old/new password it wanted, I ended up re-powering the VM. Following this it worked. I am now stuck on the next registration step. Where do I or the customer obtain the registration certificate. The only reference in the quick start guide, http://www.cisco.com/c/dam/en/us/support/docs/cloud-systems-management/common-services-platform-collector-cspc/CSPC-Quick-Start-Guide.pdf, is to say 'You should have generated and saved a Registration Certificate file from the specific service portal,
Is this generated when the customer registers through the Cisco portal?
07-07-2017 09:30 AM
Hello There,
Thank you,
Jarrett
07-07-2017 10:26 AM
Hi Jarret
Many thanks. One error on the document. You cannot use a dash (-) in the Inventory name, it says Invalid!
07-06-2017 01:56 PM
07-06-2017 03:56 PM
Hi Matthew,
Thank you for letting us know of the issue. Please review Jarrett's response to this thread and follow the steps provided. If you continue to need assistance, we ask that you start a new discussion to ensure timely response from our experts.
Cheers,
Cheri
