Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
456
Beginner
CSPC 2.7 Reports - Macro
I am generating Inventory and Alarms reports from a CSPC 2.7 with Smart Net Total Care portal v3.10, and I am having problems at using the "Template Smart Services Portal  Dashboard 3-6_v2.xlsm" macro to generate graphs with the data of the reports. The macro seems to work but the data in the dynamic tables generated is either wrong or empty.
Does anyone have had the same problem? Do you know if there is a newer version of this macro?
Thanks in advance.
Everyone's tags (1)
1 ACCEPTED SOLUTION
I had this same issue.  If
I had this same issue.  If you remove the MAC address column and load your reports it will work.
7 REPLIES 7
Beginner
It worked!! Thanks a lot.
It worked!!
Thanks a lot.
Re: CSPC 2.7 Reports - Macro
Hi, where to download this macro?
Hello Hutay,
You can reference these links:
Thank you,
Jarrett
Hi Jarrett,
Is there any way to get the latest version of the macro template, please.
Many thanks in advance.
Highlighted
Hi There,
The latest macro report can be found here -> https://www.cisco.com/c/en/us/support/services/sntc-portal/index.html
Thanks!
Jarrett
Many thanks, Jarrett!
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
