01-15-2019 09:35 PM
Good day,
Please advise, CSPC 2.7 stopped to uploading data, it shows error:
Upload failed at 01/16/2019 09 18 46 AQTT with the response
A connectivity exception occured while processing the request. The Exception is HTTPs TransportMode has Failed 407 Proxy Authentication Required
_SNTC_1547612248316 603 1
Previously it works without any problems... no additional configurations was made on our proxy.
Solved! Go to Solution.
01-27-2019 08:59 PM
01-28-2019 07:27 AM
Linux perceives certain characters as separate commands, you will need to comment those out with a \ while running the snmpwalk. I will update your private message with specifics to this issue.
01-29-2019 01:39 AM
02-04-2019 06:49 AM
Thank you for confirming the SNMP RO community string configuration on the CSPC, discoveries are now taking place as expected.
