Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
1997
mark.miller
Beginner
CSPC 2.7 Unable to login as root
I'm running CSPC 2.7 and I'm unable to login as root.  I have logged in as admin and run the pwdreset root 90 (because using 180 isn't accepted) to generate the root password.  When I go to login as root, I always get an authentication failure.  Similar experience to this post -- Root Access.  I logged in once to verify the password, but have been unable to login since, even after resetting the root password.
I'm trying to login as root because I have a hung process similar to this post -- Device Discovery not working and was trying to run the command to restart the cspc.
Any suggestions on why this is occurring with root account of the CSPC?
1 ACCEPTED SOLUTION
Jarrett Pomeroy
Hello Mark,
When trying to access the root account remotely (SSH), you will need to first login and access the user account "collectorlogin" and then use the command "su -" to change over to the root user.  Can you please see if you're able to access the shell this way?
You may also restart the CSPC service from the "admin" CLI user with the command "collector restart"
Thank you,
Jarrett
4 REPLIES 4
Jarrett Pomeroy
Hello Mark,
Thank you,
Jarrett
Jarrett,
logging in with collectorlogin first worked.
I also wound up doing this as well before I saw you're reply -- "You may also restart the CSPC service from the "admin" CLI user with the command "collector restart"
thanks.
Did you manage to fix you root access?
Please share.
Kanes.R
Hi Kanes,
Please excuse the delayed response. For fastest assistance, we suggest starting a new discussion.  Our experts have better visibility to those.
Jarrett's response below was marked as the solution.
If you continue to need assistance, please start a new discussion and our experts will be right with you.
Cheers,
Cheri
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
