10-22-2018 11:33 AM
I can access via CLI but trying to log into the GUI i keep getting Invalid credentials. Tried using the forgot password to unlock with no luck. Is there anything I can do via CLI to fix this issue? Currently using ver 2.7
10-22-2018 12:14 PM
10-23-2018 05:17 AM
yes I received it. working on it now
Thanks a lot. I'll let you know how I made out
10-23-2018 05:29 AM
was able to run the command while in root. however it did not allow for me to log into the system using the default pw...possibility i may have done something wrong
10-23-2018 08:26 AM
10-23-2018 09:28 AM
can i install the new version on top of the current version i'm running without damaging anything?
10-25-2018 08:59 AM
There is a way to deploy an ISO over an existing VM, but the new collector will still be a fresh install, meaning there will be no data saved from the pre-existing collector. I hope this helps!
Taylor
05-14-2019 02:14 AM
Hello. Can you post the workaround ? i have all cli access but i cant get the gui to work. Or send in private :)
I am using version 2.8
Br
Mathias
05-14-2019 06:46 AM
01-08-2019 11:16 AM
Hi Taywelch, I have the same problem, could you send my a potencial workaround by private
Thanks a lot
Alwinson
01-08-2019 01:39 PM
08-14-2019 08:28 AM
What is the workaround?
Romulo Araujo
08-29-2019 02:12 AM
they are a same problem about account locked, please it's possible to send me teh workaround?
Best Regards
08-29-2019 05:00 AM
09-27-2019 03:03 AM
Hi, I confirm I proceeded with the reinstallation of the collector.
