Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
1699
drburge01
Beginner
CSPC 2.7 - User admin locked using the GUI
I can access via CLI but trying to log into the GUI i keep getting Invalid credentials. Tried using the forgot password to unlock with no luck.  Is there anything I can do via CLI to fix this issue? Currently using ver 2.7
14 REPLIES 14
taywelch
I sent you a private message with a potential workaround.
thanks,
Taylor
yes I received it. working on it now
Thanks a lot. I'll let you know how I made out
was able to run the command while in root. however it did not allow for me to log into the system using the default pw...possibility i may have done something wrong
The workaround I provide via private message works on 2.7.4 and later. Any version prior will need to have the admin GUI password changed via the collector database. Currently, I believe it would be easier for you to deploy a new 2.8 VM. Please see the download link below:
https://software.cisco.com/download/home/286312935/type/286312958/release/2.8
Taylor
can i install the new version on top of the current version i'm running without damaging anything?
There is a way to deploy an ISO over an existing VM, but the new collector will still be a fresh install, meaning there will be no data saved from the pre-existing collector. I hope this helps!
Taylor
Hello. Can you post the workaround ? i have all cli access but i cant get the gui to work. Or send in private :)
I am using version 2.8
Br
Mathias
Hi Mathias,
If you loss the GUI password, you need reinstall the Collector!! ☹
AL
Hi Taywelch, I have the same problem, could you send my a potencial workaround by private
Thanks a lot
Alwinson
Unfortunately the only way I fixed the issue was to re-install all the software
What is the workaround?
Romulo Araujo
they are a same problem about account locked, please it's possible to send me teh workaround?
Best Regards
We will re-install the collector like the people recommended.
Hi, I confirm I proceeded with the reinstallation of the collector.
