Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
502
Highlighted
Beginner
CSPC 2.8.1.5 upgrade not working
My collector upgrade wont take. I have a scheduled job and the same upgrade is always "scheduled". I tried to manually apply the upgrade and it appears to work as I get logged off to do the upgrade. When I log back in the upgrade is still "scheduled". Current version is 2.8.0.1.
Everyone's tags (2)
1 ACCEPTED SOLUTION
Highlighted
Re: CSPC 2.8.1.5 upgrade not working
Hi bhessling,
Login to the CSPC CLI adminshell as the 'admin' user and run #sh ver -d
Next run #download <SP name>
To view download, run #sh download
Note you must ensure that the download has full completed before instantiating the apply/install..
To view download progress, run #sh download progress
Once completed, run #apply <SP name>
Please let me know if any of the aforementioned remains unclear and hope this helps..
-AC
4 REPLIES 4
Highlighted
Hey gordanroberts,
Have you tried upgrading via the adminshell or just the GUI?
Justin
Highlighted
Beginner
Hi - Yes i was able to upgrade it via the CLI logged in as admin.
Thank you.
Highlighted
Beginner
My upgrade from 2.8.1.4 to 2.8.1.5 also failed on the GUI.  I was sent the CSPC Software Upgrade Guide to try using the CLI.  I'm at step 4, #download <SP Patch>.  I cannot find the filename for the 2.8.1.5 patch.  I tried using the filenames "collector_2.8.1.5_Build-4.zip" and "2.8.1.5", but both failed with "Invalid package name."  What did you use for the filename?
Highlighted
Hi bhessling,
-AC
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
