Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
789
jeroenm17
Beginner
CSPC 2.9 configuring your CSPC appliance failed
when configuring the new CSPC 2.9 collector, it failed when configuring a static ip or a ip via DHCP.
Please select from the below options:
1. Get IPv4 Address automatically (Use DHCP)
2. Enter IPv4 Address manually (static IP Address)
3. Main Menu
Enter your choice : 2
Enter IP Address : xxx.xxx.xxx.xxx
Enter Net Mask : xxx.xxx.xxx.xxx
Enter Default Gateway : xxx.xxx.xxx.xxx
Configuring your CSPC appliance...
Connection successfully activated (D-Bus active path: /org/freedesktop/NetworkManager/Activeconnection/2)
Failed!
Press [Enter] key to continue
When we use option 1 we only see;
Failed!
Does anyone have seen this error before? we already had a CSPC running in the environment.
4 REPLIES 4
gausing5
I am looking into the issue and will get back to you with the updates.
Gaurav Singh
Sorry, this has allready been solved.
I am experiencing the same issue.  What was the solution you used to resolve this issue?
The CSPC VM was assigned to a wrong network, due to this is was unable i guess to ping to cisco.
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
