Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
488
adriansahota1
Beginner
CSPC and UCS B/C Series Devices - Unable to open SNMP Channel
Hello, I recently had to add some new UCS B Series Chassis to our CSPC Collector setup, however, despite the correct credentials being added (SNMP v1/v2/v3) and ensuring the SNMP is working correctly (snmpwalk confirms) the CSPC Collector simple states; Unable to open SNMP Channel. We are running 2.8.1 of the CSPC Collector tool. The UCS Fabric Interconnect itself appears to show correctly, but none of the components, and no Chassis/Blades are identified at all.
Can anyone point in the right direction to get all our UCS Blades and Chassis properly working within the tool please?
Thank you
Adrian
1 REPLY 1
jofrumki
The only node required is the Physical IPs of the FIs. Once collected then the SNTC portal will show the blades.
