01-10-2020 05:24 AM
Cisco CSPC Collector is supported on Hyper-V?
Thanks in advance.
Luciano.
Solved! Go to Solution.
01-11-2020 03:27 AM
01-10-2020 05:32 AM
01-10-2020 06:02 AM - edited 01-10-2020 06:02 AM
Hi Jaderson,
Have you installed the ISO image for appliance available on CPSC download page or other method for installation?
Thanks in advance.
01-10-2020 06:13 AM
We do not have an official Hyper-v image but you should be able to deploy using the ISO image.
see below attachment.
Using the ISO image located at :
https://software.cisco.com/download/home/286312935/type/286312958/release/2.8.1.4
01-10-2020 06:45 AM - edited 01-10-2020 06:48 AM
we have used ISO image.
This step can help you to install it using ISO: https://www.cisco.com/c/dam/en/us/support/docs/cloud-systems-management/common-services-platform-collector-cspc/CSPC-ISO-Image-Installation-Guide.pdf
01-10-2020 12:53 PM
What the hardware requirements, can I asume the same requirements for a Vmware installation?
Thanks in advance.
01-10-2020 01:28 PM
yes the specs are the same
01-11-2020 03:27 AM
01-24-2020 06:33 AM
Thanks for everybody that help!
01-24-2020 06:44 AM
