09-09-2019 05:12 AM
We´re trying for several times to upload a file and we can´t
we receive this message (in the screen below )
Exporting ==> transport-inventory-1568030060236.zip
UPLOADING (CSP0009039459) FAILED Internal Server Error
Solved! Go to Solution.
09-11-2019 08:27 AM - edited 09-11-2019 08:35 AM
Below on the attached PDF are the steps to extract the data collected and import directly into the Portal.. However Can you please send me a screenshot of the specs of your present collector?
As well as the data collection scheduled screenshot as the example below
09-18-2019 09:56 AM
09-09-2019 05:14 AM
what is the version of CSPC collector, if it version 2.7 have some issue, need to upgrade to 2.8 for fixes.
09-09-2019 07:17 AM
Hello
we´re already using .
Greetings.
09-09-2019 07:45 AM
Upload INITIALIZING: RUNNING
Upload INITIALIZING: SUCCESSFUL
Upload SELECTING_DEVICES: RUNNING
Upload SELECTING_DEVICES: SUCCESSFUL; Other Details: 488 devices selected
Upload SEGMENTING: RUNNING
Upload SEGMENTING: SUCCESSFUL
Upload EXPORTING: RUNNING; Directory: _XXXXXXXX_Profile/103_1; Other Details: transport-inventory-1568030060236.zip
Upload EXPORTING: SUCCESSFUL; Directory: _XXXXXXXX_Profile/103_1; Other Details: transport-inventory-1568030060236.zip
Upload UPLOADING: RUNNING; Certificate: CSP0009039459; Directory: _XXXXXXXX_Profile/103_1; File: transport-inventory-1568030060236.zip; Other Details: Upload method is Connectivity
Upload UPLOADING: FAILED; Certificate: CSP0009039459; Directory: _XXXXXXXX_Profile/103_1; File: transport-inventory-1568030060236.zip; Other Details: Internal Server Error
Upload CLEANING_UP: RUNNING
Upload CLEANING_UP: SUCCESSFUL; Other Details: CSP0009039459: Internal Server Error
09-09-2019 08:00 AM
Is this version 2.8.4 or 2.8.5?
Could you please share a screenshot of "Settings -> Application Settings -> Export Settings"?
Ye
09-09-2019 09:40 AM
CSPC Base Collector | 2.8 | Common Services Platform Collector (CSPC) |
Rules Package | 4.10 | Collection Rule Package for NOS, SE, SmartCare, SNTC and Evaluation services |
Agent | 1.0 | Addon Process: Intermediary between CSPC and RMC |
Update | 1.9.1 | Addon Process: Update |
09-09-2019 11:41 AM
Could you try the below:
Change the "Collection Profile Export Boundary" to 1000.
Re-download the certificate from the SNTC Portal and re-apply it on the collector under "Administration -> Server Properties -> Registration Certificate Properties -> Replace".
Then reboot the collector and try to upload again.
Ye
09-10-2019 07:02 AM
Upgraded the Version .
Raised the Collector size
and is still not uploading
09-10-2019 07:22 AM
Medium Event Upload test failed at 09/10/2019 11 03 56 BRT with the response
A connectivity exception occured while processing the request. The Exception is HTTPs TransportMode has Failed peer not authenticated
ConnectivityProbeJob_1568124235371 109 1
09-10-2019 07:35 AM
Please SSH to the collector with the user "collectorlogin" and then su to "root". If the user passwords aren't set, you can enable them in the adminshell with the "pwdreset username 1".
Then run the command "service concsotgw restart". Try to upload again.
If it still errors out, please provide the full error message.
Ye
09-10-2019 07:42 AM
Unable to login as "root"
CSP Collector
Please use below url to access CSP Collector appliance GUI
IPv4 URL : https://X.X.X.X:8001
Using keyboard-interactive authentication.
Account locked due to 82 failed logins
Password:
Access denied
Account locked due to 83 failed logins
Password:
09-10-2019 07:52 AM
Is that view from collectorlogin or are you trying to ssh as root?
Based on the lock duration, which is around 30 hours, it's probably quicker to just restart the collector if possible.
Ye
09-10-2019 10:40 AM
Now i can , to log in the device .
Cisco Network Appliance Administration
To see the list of all the commands press '?'
admin#
But i can´t to do the "SU" to be the root. Then run the command "service concsotgw restart". Try to upload again.
09-10-2019 11:07 AM
Do a "collector restart" from that prompt.
Ye
09-10-2019 11:34 AM - edited 09-10-2019 11:36 AM
admin# collector restart
Restarting Collector - please wait for couple of moments...
Collector Restarted sucessfully
admin#
And still not working .
_XXXXXXX_Profile_1568140247208 Upload failed.
It´s possible you and your team to join a session , and we share the screen ?
