Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
1254
Highlighted
Beginner
CSPC export = success but I don't see the export in "Upload Processing" on SNTC portal
I've run 2 export earlier today, I don't see them being processed on the SNTC portal. Is there an issue with the uploading of DATA at the moment?
1 ACCEPTED SOLUTION
Highlighted
The last Export I executed worked fine (I was out of the office when it occured). So we can consider this case "solved".  It auto-magically fixed itself. :D
Thanks for your support.
9 REPLIES 9
Highlighted
Hey Steve,
In a private message can you send me the collector ID? You can find the collector ID in the GUI by navigating to Help>view/manage registrations> properties.
Taylor
Highlighted
Private message sent.
Highlighted
Hi Steve,
SNTC uploading is currently being impacted by bug CSCvk29179. I will be sure to keep you informed when we receive the next updates.
Kind regards,
Highlighted
Thanks for the update.
Highlighted
Hi Steve,
Thank you for your patience. A hot fix was applied last evening.  Please reissue the upload and allow some time for it to appear in the portal.
Cheers,
Cheri
Highlighted
Ok, I've just started an upload job. I'll check later if it worked.
Highlighted
Upload fails with error 400.
Highlighted
As root, please run the below command and report back if uploads still fail after.
#service cspc restart
Thank you,
Brandon
Highlighted
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
