Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
308
Highlighted
Beginner
CSPC Filtered Device...
I have previously had a number of IP addresses included in the "Do Not Manage Devices List...", however, I have now deleted these IP addresses from the list, however, when starting a device discovery (using the IP's as removed from the list), I get an error - Status - Failed , Message - Filtered device: n.n.n.n
Any ideas?
CSPC 2.7.4.2
Andrew
4 REPLIES 4
Highlighted
Hey Andrew,
In a private message can you send me a screenshot of the do not manage device list?
Taylor
Highlighted
Hey Andrew,
I have tested and confirmed your issue with the do not manage device filter on CSPC version 2.7.4.2. As a workaround can you access the collector via CLI by first logging in as collectorlogin and then su to root. From root, you can run the service cspc restart and when the collector comes back up the discovery jobs will work for the filters IP's that have been removed.
example of workaround:
[collectorlogin@localhost ~]$ su root
Password:
[root@localhost collectorlogin]# service cspc restart
Stopping CSPC... [ OK ]
Shutting down MySQL... [ OK ]
Stopping Connectivity Tail-end Gateway: [ OK ]
Checking If Services are Shutdown... [ OK ]
Starting CSPC... [ OK ]
Starting MySQL..... [ OK ]
Starting Base Collector and Add-Ons... Starting CSPC:
Starting Connectivity Tail-end Gateway:
nohup: redirecting stderr to stdout
[ OK ]
Starting Tomcat... [ OK ]
Please let me know if this works.
Taylor
Highlighted
Will do - I have also done a collector reboot this morning which has also fixed it...
Andy
Highlighted
Hi Andy,
Thank you for confirming the workaround. I have also opened Bug
CSCvk34258 on the issue.
Taylor
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
