CSPC Notification issue
DY(Dongyeong)
I patched 2.8.1.3 successfully. However, CSPC shows me the notification, Software Update - Download of the package is failed whenever I log in to CSPC:cspc notification.PNG
Please let me know how to turn off the notification. And, it will be good if you can correct the spelling 'Succssfully' in the status description. It doesn't matter if you put it on purpose.
Bharath S
Hi Dy,
I believe there was an upgrade failed case/scenario before upgrading successfully to 2.8.1.3 , because of which the notification started to show up . It should be cleared once upgraded properly. We will check on that.
i'll be dropping you a PM with a command to clear of references which is leading to the notification please try out and update us on the result.
Thanks & Regards,
Bharath S
Bharath S
Hi Dy,
Thanks & Regards,
Bharath S
Thanks a lot, Bharath! It worked for me.
