12-15-2015 05:18 AM - last edited on 07-27-2018 11:18 AM by Cheri Fairbrother
Hi Guys,
I am currently working through the discovery of our network devices using the Cisco CSP Collector version 2.5. After running an SNMP discovery it appears that ASA's are not supported correctly, they appear as GenericNetworkDevices and the inventory contains no information about the device.
What is the solution to discovering ASA's using the CSP collector?
Matt Smith
Solved! Go to Solution.
12-15-2015 02:29 PM
Hi Matt,
ASA 5505/5510/5520 are supported and should show up under the Security section.
Ensure you are using the same SNMP RO string as well as add your collector IP address to the SNMP-Server ACL.
Buz
12-15-2015 02:29 PM
Hi Matt,
Buz
