CSPC Support for ASA
matt-smith1
Hi Guys,
I am currently working through the discovery of our network devices using the Cisco CSP Collector version 2.5.  After running an SNMP discovery it appears that ASA's are not supported correctly, they appear as GenericNetworkDevices and the inventory contains no information about the device.
What is the solution to discovering ASA's using the CSP collector?
Matt Smith
steve.busby
Level 5
Level 5
Hi Matt,
ASA 5505/5510/5520 are supported and should show up under the Security section.
Ensure  you are using the same SNMP RO string as well as add your collector IP address to the SNMP-Server ACL.
Buz
steve.busby
Level 5
Level 5
Hi Matt,
Buz
