CSPC SW 2.8.0.1 > 2.8.1.2 update failing
danielbarri
We got error  “unable to get data from server for report: available updates(see attached) when trying to update SW.
Tried rebooting the collector and Disabling/Enabling CCO ID Server Connection
Do we need to proceed with manual sw update via CLI as in:
https://community.cisco.com/t5/smart-net-total-care-portal-and/software-updates-server-is-down/td-p/3096102
Bharath S
Hi Daniel,
Can you please try clearing the cache once and re-login to CSPC UI and update us if you still see the same behavior ?
Thanks & Regards,
Bharath S
Clearing the cache did not help. We did a manual update, i.e. downloaded the file collector_2.8.1.2_Build-10.zip and installed it manually.
