08-08-2017 12:13 PM
I am having an issue with my USPC. If I select multiple IPs for discovery, most fail with a "SNMP Unreachable or Incorrect SNMP Credentials.".
If I pick an IP that failed out of the multi IP discovery and discover it individually, it discovers fine. I use all the same settings from the failed discovery.
I have verified that the USPC is hitting the IPs that fail during the multi IP discovery via 'debug snmp packets'.
I am running 2.7.1
Please let me know if you have any questions.
Thank you,
Aaron
Solved! Go to Solution.
08-09-2017 07:21 AM
Jarrett, I sent you a PM.
I looked into it a bit further this AM and it looks like our EngineID was hard coded on the devices I am having issues with. I will have to go ahead and resolve this issue.
Thank you for your help.
08-08-2017 01:06 PM
Hello ambliven2,
Can you please let me know if you are using SNMP v3 settings or V2?
Thank you,
Jarrett
08-08-2017 01:17 PM
Hello Jarrett,
We are using SNMP v3.
08-08-2017 02:57 PM
Jarrett,
I looked at another post of yours... I see where you are going with this.. same engine ID.
Is there a better work around in 2.7.1? I don't show the code that were are running as being affected in the bug search for 'CSCts87275'.
Please let me know how best to proceed.
08-09-2017 05:26 AM
Hi ambliven2,
Yes, you are correct :) The behavior was similar to what we have seen when encountering non-unique engine IDs across devices.
Would you be able to provide me some additional details about your devices? OS Version and PID? You may also send a private message using these steps here as well for these details.
Thank you,
Jarrett
08-09-2017 07:21 AM
08-09-2017 08:34 AM
Hello ambliven2,
Thank you for the follow up and great to see it's working for you now!
Thank you,
Jarrett
