Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
732
ditti.tech
Beginner
CSPC Unmanage devices
I have a discovery job schedule every day with a lot of IP Address:
10.100.0.0-10.100.15.255
This work fine.
Now I want to unmanage 2 IP in this range :
10.100.1.100   /   10.100.6.12
I include this IP in Device Management > Credential Management > Do Not Manage Devices List.
But after each discovery, the IP come back
Is there a way to exclude IPs ?
1 ACCEPTED SOLUTION
After a reboot of the server CSPC, the filter work fine
6 REPLIES 6
jofrumki
If you want to prevent the CSPC from managing devices while running a discovery, you can add these to the Do Not Managed List located under the Settings menu.
The option you have selected in the Device Credentials is only to prevent the selected devices from being inventoried during a collection job.
Thank you,
It's same menu, look print screen, but it doesn't work
I have the version 2.7.3
Thank you for the update.
Please make sure you have unmanaged these devices as well from Management -> Unmanage Devices... before you run a new discovery job. Coupled with the Do Not Manage list this will ensure your do not discover the offending devices again.
Yes that was done.
Thank you for the update, I'm glad it is working now.
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
