04-05-2018 06:09 AM - edited 03-12-2019 07:43 AM
I'm unable to upgrade Collector because it seems that the file downloaded is corrupted.
Command "apply sp-30.0.4-0-0-lnx64" doesn't work because of that and I can't download again the file, it tells me that the file was already downloaded.
See below;
admin# show version -d
Build-name : Collection Platform Software 2.7.3.2
Package-type : ServicePack
Version : sp-30.0.3-2-0-lnx64
Component : CSPC Base
Version : 2.7.3.2
Package-type : JeOS
Version : jeos-30.0.3-2-lnx64
Component : AdminShell
Version : 1.6
Component : LCM
Version : 1.6
Component : CASP
Version : 2.7.3.2
Component : ConcsoTgw
Version : 1.7
Component : Hardened CentOS
Version : 6.8 patch#0
Show download:
Version : sp-30.0.4-0-0-lnx64
Download Location : /opt/LCM/tmp/sp-30.0.4-0-0-lnx64-package.zip
Status : Downloaded
Start Time : Nov/19/50201 23:17:01
End Time : Mar/27/2018 13:39:54
Reason For Failure : -
Show apply:
Version Number : sp-30.0.4-0-0-lnx64
Status : Apply-failed
Start Time : Apr/04/2018 10:40:14
End Time : Apr/04/2018 10:40:27
Reason : Package file "jeos-30.0.4-0-lnx64.zip" not in expected format
Any idea?
Thanking you in advance.
Renaud
Solved! Go to Solution.
04-10-2018 12:45 AM
Please Delete the files from /opt/LCM/tmp (cd /opt/LCM/tmp) and Try Upgrade again from CLI using below commands
#download sp-30.0.4-0-0-lnx64
#apply sp-30.0.4-0-0-lnx64 --- once download completed.
Please update us once the above steps are completed.
04-10-2018 12:45 AM
04-10-2018 06:10 AM
Thank you. In the meantime I've done a new download et it's being applied.
I'm waiting the end of the process:
Status : Apply-in-progress
Start Time : Apr/09/2018 16:38:16
End Time : -
No boudt that it will end correctly.
Thank you
Renaud
04-30-2018 03:06 PM
Is this still the same guidance? Having the exact same issue. Can delete the previous file and attempt download again, checked CCO credentials, all appears normal but the file never actually downloads. Keep getting the same error message and it appears the file is very small (2.2k).
04-30-2018 07:21 PM
Run below command from "root".
su admin and run below command
sh download.
Please check if the status says "downloaded" and the size is not correct then proceed with the steps to delete the files and re trigger the upgrade.
Please tails the install logs while the patch is being downloaded (tail -f /opt/LCM/logs/install)
05-01-2018 09:16 AM
05-03-2018 09:10 PM
Was the status showed as "downloaded" when "sh download" command executed in adminshell?
If so there could be some issues with the download center, can you please try again after deleting the file from /opt/LCM/tmp if the size of the file is not as expected.
also if possible please attach the logs (/opt/LCM/logs/install) and (/opt/cisco/ss/adminshell/logs/lcmlog.log)
05-04-2018 07:15 AM
