08-28-2017 05:50 AM - edited 03-12-2019 07:28 AM
Good Morning !!
Dear, CSPC collector is not looking for all IP Phone information from CUCM, I would like to know if cisco has any tool to get device information or some command so I can import the IP Phone information, and feed it CSV spreadsheet for manual import into the SNTC portal.
Best Regards
Solved! Go to Solution.
08-28-2017 06:15 AM
Good morning.
From within the call manager, you should be able to generate reports on the managed phones.
SNTC would need you to provide either the serial number or mac address for each phone. Please view the following guide for some instructions on how to generate reports. https://www.cisco.com/c/en/us/td/docs/net_mgmt/cisco_unified_operations_manager/8-5/user/guide/cuom_userguide85/useIPRpt.html
It should be very similar for other versions of call manager.
Cesar
09-08-2017 01:21 PM
Hi William,
As this issue seems to be on the call managers themselves, please continue to work with the CUCM support team or support community as this falls beyond the area of expertise for the SNTC support team.
Cheri
08-28-2017 06:15 AM
Good morning.
Cesar
08-28-2017 06:16 AM
Can you explain a little more what you mean by CPSC not looking for all IP Phone information from CUCM. If you have CUCM in CSPC and it is successfully collecting, then it will gather all the phones reported by CUCM. You can upload a manual CSV of the phones inventory (PID and Serial Number), but if you have CSPC, I would recommend having it collected dynamically.
08-28-2017 06:27 AM
08-28-2017 06:27 AM
The CSPC can help to find the phones associated to a call manager during inventory. If you are not seeing any phones collected, you may want to check if the SNMP Service has been enabled on the CUMC.
Here are some addtional guides as well with go over the CSV Option too.
User Guide - https://www.cisco.com/c/en/us/support/docs/services/sntc/portal_user_guide.html
File Import Video Training - https://www.cisco.com/c/en/us/support/services/sntc-portal/video-resources.html?videoId=5384981150001
Thank you,
Jarrett
08-28-2017 06:52 AM
08-28-2017 06:56 AM
08-28-2017 08:18 AM
08-28-2017 08:19 AM
09-08-2017 01:21 PM
Hi William,
Cheri
