Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
394
ditti.tech
Beginner
CSV file schedule report with Smart Net Total Care 4.3
I would like to schedule a report as a csv file but we can't select csv, is it possible ?
Actions - Schedule Reports - Custom Inventory Report (view screenshot)
However, if we go through :
Library - All Hosts - Export, we can export to csv
Nicolas
1 ACCEPTED SOLUTION
Jarrett Pomeroy
Currently for Scheduled SNTC report exports, some reports allow Excel or PDF export options only (depending on the report) and not CSV at this time. As you mentioned, directly on the report UIs, there is also the CSV option for those pages.
Thank you,
Jarrett
1 REPLY 1
Jarrett Pomeroy
Thank you,
Jarrett
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
