11-27-2019 07:36 AM
HI,
I need to know when was "the first time seen" on portal of a list of Serial Numbers.
I need a report with the exact date of an item was discovered.
Any help is highly appreciated
Solved! Go to Solution.
11-27-2019 08:25 AM
11-27-2019 09:35 AM
11-27-2019 08:25 AM
11-27-2019 08:48 AM
Hi Jarret,
Thanks for your quick reply
Is there a way to access the CSPC GUI in the SNTC portal?
If so can you tell me how to access it, I have been searching for it for a long time now with no luck.
Thanks!
11-27-2019 09:35 AM
