Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
368
eagueros
Date collected of an specific Serial Number
HI,
I need to know when was "the first time seen" on portal of a list of Serial Numbers.
I need a report with the exact date of an item was discovered.
Any help is highly appreciated
2 ACCEPTED SOLUTIONS
Jarrett Pomeroy
You can find the first discovery date of a device on the CSPC GUI in the "Manage Device List".
Thank you,
Jarrett
Hello Enrique,
Unfortunately CSPC UI access is not available directly from the Portal. You can reach out to the customer and request them to look up the device locally on the CSPC UI. You will navigate over to Reports -> Managed Device List -> Search for IP and see the data.
Thank you,
Jarrett
3 REPLIES 3
Jarrett Pomeroy
Thank you,
Jarrett
Hi Jarret,
Thanks for your quick reply
Is there a way to access the CSPC GUI in the SNTC portal?
If so can you tell me how to access it, I have been searching for it for a long time now with no luck.
Thanks!
Hello Enrique,
Thank you,
Jarrett
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
