04-09-2018 12:06 AM - edited 03-12-2019 07:44 AM
I am unable to find detailed logs from CSPS discovery job. Under Log Prefrences is "debug" selected for Discovery. Where can I find job logs in CLI? Is there some separate log file for every Job process?
My OSPF neigbors are not discovered, so I would like to investigate discovery logs for details.
Thank you
Pavel
Solved! Go to Solution.
04-09-2018 07:59 AM
04-09-2018 07:59 AM
04-10-2018 03:20 AM
04-10-2018 03:41 AM - edited 04-10-2018 12:07 PM
I thing, there is problem with OSPF and vrf-lite. I see only OSPF neighbours (using SNMP request) behind interfaces without "ip vrf forwarding" command.
I need to modify my cisco snmp settings and use "snmp context" :-)
Bets Regards
Pavel
04-10-2018 01:28 PM
Hi Brandon,
If you are running an snmp-server instance per VRF then you can try to create a single SNMP context and map each snmp-server VRF instance to that context. To test if that context will report all your OSPF neighborships you can use the -N flag with snmpwalk to define the context name.
You may find this link helpful.
Thank you,
04-10-2018 01:38 PM
Hello maybe there is a misunderstanding here, I believe you are saying that on the managed device list is only showing devices that can reach SNMP. There is by design you may learn a device exist via ping or protocol but it can only be managed by SNMP. SNMP reach-ability is required. Please lets know if the devices you are trying to discover do have access to SNMP.
