Enterprise Monitoring for CSPC 2.6
twylyghtcisco
Management has requested that logging to our SIEM service is enabled for our virtual CSPC appliance.  I have the destination IP address and port at the ready for the SIEM server, but I see no configuration options (GUI or otherwise) for this monitoring to take place
I appreciate any and all help that can be offered in this matter.
My thanks for the reply sir.  I ended up logging in with root access for the virtual appliance and modifying the rsyslog.conf file with a modified syntax of two "@"s rather than the single one.  Once that was done, the system began forwarding its logs accordingly.
Jarrett Pomeroy
Would you be able to help provide us with some additional information about your SIEM application?  Once we have some additional details, I can help to check and see if this integration is supported by the CSPC.
Please let me know if there are any questions.
Thank you,
Jarrett
Glad to hear it's working for you now!  And thank you for providing the steps you used to set up this type of monitoring.
Thank you,
Jarrett
