Error in upload profile
Alexandre11
Hello, We did a Run Collection profile and the Upload was not successful. We created an Upload profile to run some troubleshooting and find attached the error. Could you please adviceError collector.JPG
It's solve.
In Settings - Application Settings
Export Settings
I changed to Upload via: Transport Gateway and works.
6 Replies 6
adias
The Internal Server error is a generic error and we need to find a more specific root cause
We will need to connect via ssh to the user collectorlogin and then su to root
if you only have access to the admin cli user (reminds that the authentication of admin CLI and not the same as the GUI per se )you can activate and generate the passwords with the commands below
If you do have have that access connect via SSH using the admin user and its passwords ad do the following :
admin#  pwdreset collectorlogin 90
and
admin# pwdreset root 90
If you already have access to collectorlogin and root access do the following
Connect to the user via ssh collectorlogin then su to root as shown below
$ su root
and then send me the output of the following commands on a private message.
# tail -100 /opt/ConcsoTgw/tail-end-gateway-decoupled/bin/CONN_TEG_LOGS/tail-end-gateway.log
# openssl s_client -showcerts -connect concsoweb-prd.cisco.com:443
# tail -100 /opt/ConcsoTgw/tail-end-gateway-decoupled/bin/nohup.out
# wget https://72.163.7.113/HeadEndWebAppServlet/ --no-check-certificate
Commands attached.
Thank you for providing the logs the present specific error found on the logs is :
196: 0.0.0.0: Nov 25 2019 06:50:16.441 -0200: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp718689743-23][className=com.cisco.ca.csp.conn.gateway.tailend.core.command.SendFileCommandHTTPS][methodName=uploadFileILB][lineNumber=499][isRemote=false]: message: uploadFileILB...
197: 0.0.0.0: Nov 25 2019 06:50:20.035 -0200: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp718689743-23][className=com.cisco.ca.csp.conn.gateway.tailend.core.command.SendFileCommandHTTPS][methodName=uploadFileILB][lineNumber=625][isRemote=false]: message: Send File failed,http status code:503
198: 0.0.0.0: Nov 25 2019 06:50:20.036 -0200: %CONN_TEG-6-CONN_STR_INFO: %[ch=connectivityteg][mid=10003][requestTranId=99999999][applianceId=CSP0009043822][customerId=4548579][source=Connectivity][component=CONN_TEG][threadName=qtp718689743-23][className=com.cisco.ca.csp.conn.gateway.tailend.core.command.SendFileCommandHTTPS][methodName=uploadFileILB][lineNumber=628][isRemote=false]: message: Send File failed,http status:Service Unavailable
This particular error denotes synchronization problems and requires the configuration on NTP server on the collector.  Please with the IP of NTP you use in your organization connect via ssh to the user admin and issue the following command
[collectorlogin@localhost ~]$ su
Password:
[root@localhost collectorlogin]# su admin
Cisco Network Appliance Administration
To see the list of all the commands press '?'
admin# timesync
Synchronize Appliance Time
Ntp Server Address [pool.ntp.org] :                           <-----
Then run upload again,  if successful please return to this post and mark as resolved...if it gives the same generic or other error message please send me the new logs.. it is not uncommon once we fix this issue to  perhaps have another issue with a different error message
I set up ntp
   Ntp Server Address [pool.ntp.org]: 10.99.255.2
   Would you like to synchronize time with '10 .99.255.2 '(y | n)? y
Successfully updated NTP sync interval
I started the upload and showed the message below:
Attached Files.
It's solve.
Export Settings
