Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
522
Highlighted
Beginner
Error while Applying Trial License.Not able to connect to Cisco backend.Please try after sometime.
I'm trying to install a Trial of CSPC with my CCO but it gives me this error when I set up "Register the collector without registering with any service (trial)" and my acount, so I can not move forward. please your support to resolve that.
6 REPLIES 6
Highlighted
Can you confirm what version the collector is on and if a proxy is configured?
Taylor
Highlighted
We do not have a proxy for this service, the computer has its DNS properly configured and it has internet access.
Build name: Collection Platform Software 2.7.4
Version: sp-30.0.4-4-0-0-lnx64
Highlighted
Do you have any progress on this problem?
I would like to know if you need any additional information to help us set up the trial.
Highlighted
When the collector tries to apply for a trial license, it will try to connect to concsoweb-prd.cisco.com (72.163.7.113). Can you confirm the collector has connectivity to concsoweb-prd.cisco.com?
Taylor
Highlighted
Hello
I have an answer from the indicated ip
admin# ping 72.163.7.113
PING 72.163.7.113 (72.163.7.113) 56(84) bytes of data.
64 bytes from 72.163.7.113: icmp_seq=1 ttl=234 time=102 ms
64 bytes from 72.163.7.113: icmp_seq=2 ttl=234 time=95.0 ms
64 bytes from 72.163.7.113: icmp_seq=3 ttl=234 time=89.3 ms
64 bytes from 72.163.7.113: icmp_seq=4 ttl=234 time=97.4 ms
64 bytes from 72.163.7.113: icmp_seq=5 ttl=234 time=95.4 ms
--- 72.163.7.113 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4101ms
rtt min/avg/max/mdev = 89.351/95.866/102.044/4.118 ms
admin#
and by name
PING concsoweb-prd.cisco.com (72.163.7.113) 56(84) bytes of data.
64 bytes from concsoweb-prd.cisco.com (72.163.7.113): icmp_seq=1 ttl=234 time=89.9 ms
64 bytes from concsoweb-prd.cisco.com (72.163.7.113): icmp_seq=2 ttl=234 time=89.3 ms
64 bytes from concsoweb-prd.cisco.com (72.163.7.113): icmp_seq=3 ttl=234 time=109 ms
64 bytes from concsoweb-prd.cisco.com (72.163.7.113): icmp_seq=4 ttl=234 time=89.9 ms
64 bytes from concsoweb-prd.cisco.com (72.163.7.113): icmp_seq=5 ttl=234 time=89.2 ms
--- concsoweb-prd.cisco.com ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4094ms
rtt min/avg/max/mdev = 89.218/93.683/109.960/8.144 ms
When I am setting up a trial, should I be registered in the STNC portal with a valid contract?
Highlighted
A valid contract is not required to register the collector in eval mode since the collector cannot upload with an eval certificate. Can you restart the collector and run a packet capture on the traffic leaving the collector when you try the eval cert again?
Taylor
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
