Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
313
Beginner
eth0 error
Dears,
I need a help.
I cant configure a IP address on Access Cisco Network Appliance.
A few days ago the collector was configured with IP DHCP and it was running successfully.
After a power failure, the UCS server was rebooted and the machines was power on again. Now, the command show ipconfig show which "Device eth0 does not exist".
In editing settings I changed the VLAN and restarted guest but unsuccessfully.
Can I use another interface without problems? I saw that Eth1 is the gateway.
1 ACCEPTED SOLUTION
Highlighted
Hello Jujubasc1,
Hello Jujubasc1,
Thank you for your question! Additional interfaces may have been assigned to the hardware during the power failure.  Can you please try resetting the Eth0 mapping by running the below commands?
“sudo rm -f /etc/udev/rules.d/70-persistent-net.rules”
“reboot”
Thank you,
Jarrett
1 REPLY 1
Highlighted
Hello Jujubasc1,
Hello Jujubasc1,
“reboot”
Thank you,
Jarrett
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
