06-23-2022 06:56 AM
I am getting the message "Your account has expired; please contact your system administrator" when attempting to log in CLI on either console or SSH with the collectorlogin username. Need assistance in recovery.
Solved! Go to Solution.
06-23-2022 07:53 AM
Hi Tom,
Please try to access the VM console and login there as root.
Use the same command pwdreset collectorlogin 90.
Please let me know if this works for you.
Agrim
06-23-2022 07:12 AM
Hi Tom,
My name is Agrim Kher and I will be handling your request.
Please let me know if you are able to login as admin. If yes, please type pwdreset collectorlogin 90
Please let me know if the above steps worked for you.
Agrim
06-23-2022 07:21 AM
06-23-2022 07:53 AM
Hi Tom,
Agrim
06-23-2022 08:38 AM
I was able to reset all my passwords. Sequence:
Log in as root from console, reset the root password at login
As root on console, su admin, reset the admin password as prompted
SSH as admin, used pwdreset collectorlogin 90
Thanks for the assistance.
06-23-2022 09:33 AM
Hi Tom,
Thanks for the update.
Please let me know if you need anything else
Agrim
