11-01-2016 05:44 AM
when I run ''run upload profile'' it said successful but I cant found it in upload processing as the newest one was two months ago
I tried to run it several time but with no change
11-02-2016 12:48 PM
Hi Mahmoud,
Manually run uploads will show under Reports > Job Management Reports > Upload Run Now Jobs
Scheduled uploads will show under Reports > Job Management Reports > Upload Jobs
Lynden
11-03-2016 06:56 AM
thanks Lyden for your support
but my question is when I upload data to the cloud I cant see this data as my last one was two months ago
11-04-2016 07:40 AM
On the SNTC portal, when you go to Library > Administration > Upload Processing, you say that you aren't seeing an upload for over two months?
If you check the uploads on the collector (Reports > Job Management Reports > Upload Run Now Jobs), are they running successfully?
11-06-2016 05:35 AM
11-07-2016 07:34 AM
It looks like the GUI has lost connection to the server. Try rebooting the server and then view the jobs again.
11-09-2016 03:50 AM
11-09-2016 06:33 AM
Could you expand the latest job (Nov 6) and see if it completed successfully?
11-14-2016 11:59 PM
Yes I can see it completed successfully
11-17-2016 10:28 AM
On the SNTC portal (tools.cisco.com/smartservices) if you click Library > Administration > Upload Processing, do you see a job that came in on Nov 6? Did it finish processing?
