Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
736
Beginner
FAILED: SNAS validated data not available
Can you validate what this description code means, "FAILED: SNAS validated data not available".
This reason code stems from items that were not recognized as a Cisco device based on the collected device information.  I'm trying to determine if remedial action is required to get these items recognized.
Thanks.
Everyone's tags (2)
2 ACCEPTED SOLUTIONS
Highlighted
Beginner
Re: FAILED: SNAS validated data not available
PM sent
Beginner
SNAS stands for Serial Number Assessment and it a part of the processing done by the SNTC Portal.  The reason code populated in my case due to some of the chassis were VMs that's didn't have serial #s.  The rest were IP Phones and Cisco is only able to collect (via SNMP) MAC Address directly and not a serial number, so they do a lookup to try and find the serial numbers within the Portal if available.
8 REPLIES 8
Hello Craig,
This error may indicate that the Portal/CSPC was unable to find a valid device PID or Serial Number from your device during collection or processing. Would you be able to provide me some more details about the Inventory name/Device you saw the error for in a private message? I can take a deeper look and see why the message was displayed.
Thank you,
Jarrett
Highlighted
Beginner
PM sent
Beginner
I have the same issue with several devices.  Was it determined what the reason is?
Beginner
Hello, I have around 280 devices with that error message, but all of them are either cisco routers or switches. What could be the issue for that or is there anything I can do to fix that.
Thank you Alexander
Hi Alexander,
Please PM me your account and device details (IP/hostname, SN) and I can take a look.
Ye
Beginner
Hi!
I am experimenting the same issue with 4 devices, could you provide me the accions to take for solve this issue please?
Regards.
Please check on the collector under "Reports -> Inventory Collection Reports -> View Collected Data -> View Data ->
if you can find your device. In my case there were not there. What helped me to fix the issue in my case was to re-enter the SNMP Password and to rediscover the devices. Afterwards the problem was solved to me.
Hope it helps you as well.
Alex
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
