11-22-2018 08:57 AM
Customer´s inventory show a series of devices that appears as Serial Number Not recognized.
Between the devices are IP Phones models: 7841, 7861, 8845 and some FANs too.
For IP Phones I have FALLOUT REASON: Input Processor:MAC convertion not found, and for FAN I have FAILED: SNAS validated data not available.
Could you help me, please?
Luciano.
Solved! Go to Solution.
12-13-2018 07:45 AM
Apologies. I mistyped before. I meant to say we have no other way to get the serial number from the MAC Address. We already correctly have the MAC address, but the data isn't available to convert that to Serial Number.
11-26-2018 07:39 AM
11-27-2018 04:59 AM
11-30-2018 02:24 PM
I think the PID checker isn't differentiating when IP Phone Serial numbers won't be possible.
11-30-2018 03:31 PM
I got info on the PID checker and it does have a classification for "Partially Supported - excludes contract coverage reporting". When I did some research on Phones that cannot resolve MAC address, it seems to be limited to CP-7935, CP-7936, CP-7937G, and CP-8865. A third of the time CP-7811 won't have a SN. Again, if you private message me with the customer name and inventory name along with some example devices, I'll take a deeper look to see why you might have these results.
12-03-2018 04:53 PM
12-05-2018 08:17 AM
For the switches you sent in private message, you can see from show inventory they aren't even recognized there. These switches do have a FRUable FAN but there is no electronic serial number available for them. That is why you get the fallout message because there is no serial number to validate.
12-13-2018 05:06 AM
12-13-2018 07:23 AM
I didn't see the attachment, but I'm not sure what you are still trying to accomplish. I think I answered about the Phones and the Fans. Can you clarify what open question you still have?
12-13-2018 07:39 AM
12-13-2018 07:45 AM
12-13-2018 08:25 AM
12-13-2018 08:33 AM
For the Fans, there is nothing that can be done because there is no electronically programmed serial number.
For the IP Phones, the Callmanager only reports MAC Address and doesn't have serial number. We do not collect directly via HTTP from all the IP Phones, which is the only other way to get IP Phone serial number. As a result we are dependent on being able to translate MAC Address to Serial Number using backend systems. But not all IP Phone models are represented there as I previously shared. As a result, there will be no way to have those serial numbers in the portal from CSPC. You can manually get the serial numbers yourself from the HTTP interface on each phone and use CSV upload in SNTC to add them.
12-13-2018 09:55 AM
12-13-2018 10:39 AM
Hi There!
Your attachment does not show up here on the forum.
However you should be able to find sample CSV format here
You can follow the instructions from sample CSV, and import the manually collected serial numbers via Administration - File Import.
