07-11-2019 10:35 AM - edited 07-12-2019 09:23 AM
I uploaded a csv file that included 42 wireless controllers yesterday. It is still in progress, over 24 hours. Could you help me to resolve it? Also, I'd like to know how I can avoid this issue in the future.
I did:
1. downloaded sample csv.
2. filled out 'mandatory' columns - 43 wireless controllers both primary and secondary
3. submitted the file.
I am wondering when it is possible to discover secondary WLC. I thought it would be possible if I set CLI credential in CSPC to access standby WLCs, 'show inventory' to collect the serial number. However, it didn't work.
Thank you,
DY
Solved! Go to Solution.
07-11-2019 06:00 PM
CSV file import can take upto 48 hr and as of now, i can see that it is IN PROGRESS status. As per current, only active will be discovered/uploaded via CSPC. We have enhancement in line where WLC in HA redundancy which allows SNMP collection from the WLC Standby.
Supriya
07-11-2019 06:00 PM
Supriya
07-12-2019 09:17 AM - edited 07-12-2019 09:23 AM
Thank you, Supriya. It is in success now.
For other SNTC users:
- CSV file upload took 45 hours in my case.
- The file included 42 wireless controllers with Hostname, IPAddress, SerialNumber, ProductID.
