Firepower 1140 (ASA-Image) - SNTC Portal/Collector
Michal Navorka
is it possible to get information from Firepower 1140 device with Cisco ASA image to Cisco CSP Collector? When I do it via standard procedure of SNMP pull from ASA - it wont return any Serial Number - just basic info.
I suspect it will be same issue as with Firepower 2210 with FTD image - that CSP needs to access FXOS to get the info.
Any procedure/help how to set it up so we can have those devices in a collector also?
Thanks.
Chris Camplejohn
This should work fine for FPR1K/2K by just managing the ASA management IP in CSPC. You don't need to access FXOS for those. The SN may not show in CSPC, but it would show in SNTC portal.
