Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
788
Ernesto Garcia
Beginner
Generic Device or Unknown status SNTC 2.7
After doing the discovery I have many devices with status Generic Device or Unknown, in the report that I export in the status of Reacheable this is false, In those devices already validate the configuration of SNMP and it is configured correctly. The majority are devices that have this status are Cisco Adaptive Security Appliance Software Version 9.4 (2) 3 5555. What do you recommend to review?
1 ACCEPTED SOLUTION
hperezar
Hello Ernesto here the commands for SNMP walk keep it in mind you have to replace data according to your environment in this case SNMP community
snmpwalk -v 2c -c <snmp-Community> Device IP address
6 REPLIES 6
Chris Camplejohn
If they are not reachable then you didn't have SNMP reachability to the devices. Have you checked that you can manually snmpwalk to the ASA firewall from the CLI of the CSPC? Likely your SNMP credential isn't right in CSPC or your ASA isn't configured with that credential to allow the CSPC's IP from the right security interface.
Will you have the snmpwalk command that I can send from CSPC CLI to be able to do the test?
you should be able to do "snmpwalk -c <your_community_string> -v2c <asa_ip_address>"
hperezar
Hi Ernesto,
Please let us know if you need further assistance.  If not, mark Accept as Solution to close the conversation.
Cheers,
Cheri
Sorry for the delay. We have already reviewed the snmp community configuration for our devices and have already been added correctly. Thanks for the support.
Create
Recognize Your Peers
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
