Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
378
Beginner
Have Access, Can't Access
I'm having an issue where I try to log in and it says I don't have access and need to register.  I go to register and it says I already have access.
https://streamable.com/t1jpx
Nick
Everyone's tags (2)
1 ACCEPTED SOLUTION
Re: Have Access, Can't Access
Can you please retry accessing the portal and let me know if you still face any issue
9 REPLIES 9
Beginner
All fixed, thank you for the rapid response.
It seems I encounter the same issue where I've been provided access by my administrator but once I login it redirect me to another page (https://www.cisco.com/web/fw/tools/ssue/apps/ssueap2.0/prod/#/promo) I registered and I must say I'm a bit stuck now. When I tried to register again it says I'm already registered. Can you help me out?
Are you able to login directly into SNTC at services.cisco.com?
Yes I can. Can it be linked to the fact that I have no contract linked to my userId?
If you are able to access the SNTC portal, then no further action is needed. Your user already has all the access it needs.
Is there a particular action you need to perform?
Well I need to run some reports that is all.
Try running your reports, if you encounter issues, please share them here for further troubleshooting.
Regards.
Ok nevermind, now it's working I got access to the SNTC portal. Not sure why it wasn't accessible right away however.
I'm sorry for the inconvenience and thanks for your help!
Problem solved by itself!
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
