how to add customer to smart net total care
8 Replies 8
asingadi
Hi Mohamed ,
Thanks for reaching out to cisco .
Delegated Administrator (DA) need to log in to the Cisco Services Access Management tool and provide the role access to the user .
In below URL you can find the steps for  Adding New Users to the Smart Net Total Care Portal by DA :
https://supportforums.cisco.com/document/12583596/adding-new-users-smart-net-total-care-portal
Here are links to several detailed "How to" videos about user setting up user access to the portal.  Here are the links:
Delegated Admin Overview:
http://www.cisco.com/E-Learning/bulk/subscribed/SNTC_vods_EN/Delegated_Administration_Overview.mp4
User/Company Association:
http://www.cisco.com/E-Learning/bulk/subscribed/SNTC_vods_EN/User_Company_Association.mp4
Assigning Roles:
http://www.cisco.com/E-Learning/bulk/subscribed/SNTC_vods_EN/Assign_Role.mp4
The full library of videos is accessible via the Community here:https://supportforums.cisco.com/community/12286826/how-videos
Please let me know if you have any further query .
Anusha.
Dear Anusha ,
thank you , We need to deploy the collector for the new customer and then register it .
but when we login to smart net total care portal we find only EDC customer
and we need to add new Customer called TOTAL .
Also when select all collector and try to download entitlement we face an
issue
Entitlement file generation failed. Please try again. If the issue persists,
find help in the community.
Hi Mohammed,
Could you please try to generate the entitlement again, i am not facing any issue from my end
All Collector -> Action -> Global -> Generate a new CSPC-C entitlement .
Anusha.
Dear Anusha,
when we are login to https://tools.cisco.com/smartservices/ there are two option under services TAP :-   smart care or smart net total care.
when we select smart net total care we can not download entitlement .but when we select smar care we can download entitlement.
but on both of them we have only one customer  and we need to add another customer is this available.
Best Regards
Mohamed Basal
Hi Mohamed ,
I am working on this issue , will update you .
Anusha.
Hi Mohamed ,
I am working on this issue with the engineering team , once the issue is fixed i will update you .
Anusha.
Hello, I have the same problem, I can't add a new customer, could you do it??
Juan Carlos Arias
Hi Anusha,
How can I add another customer to the portal?
Appreciate your reply.
