Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
I have had issues with time settings in the past. Is there a way in 2.8 to see the current time on the server?
thank you
Solved! Go to Solution.
Hey mgayle083,
On the CSPC GUI, you can see this by going to 'Administration' -> 'Server Properties' -> Scroll down to Server Time Properties.
On the CSPC CLI, you can run command 'show date' from the admin shell. You can sync up to an NTP server from admin as well by running 'timesync' and entering your desired server or just enter for the default NTP server.
Justin
Hey mgayle083,
Justin
