Welcome to the Smart Net Total Care Community!
Our community includes Cisco experts to answer your questions about the Smart Net Total Care (SNTC) portal and CSP-Collector.
Click the navigation links below to access materials for using our service and supported collectors.
268
SDaniels1
Beginner
https://tools.cisco.com/smartservices/ = 404 Not found ?
Hi.
I am attempting to view https://tools.cisco.com/smartservices/ after logging in with my CCO acount but I am presented with the following when visitng that URL:
Not Found
404
Error: Not Found
    at /opt/app-root/src/repo/server.js:267:26
    at layerObj.handle (/opt/app-root/src/repo/node_modules/appdynamics/lib/probes/express-probe.js:164:20)
    at beforeExecLogic (/opt/app-root/src/repo/node_modules/appdynamics/lib/core/proxy.js:229:31)
    at returnFunc (/opt/app-root/src/repo/node_modules/appdynamics/lib/core/proxy.js:513:30)
    at Layer.handle [as handle_request] (/opt/app-root/src/repo/node_modules/express/lib/router/layer.js:95:5)
    at trim_prefix (/opt/app-root/src/repo/node_modules/express/lib/router/index.js:312:13)
    at /opt/app-root/src/repo/node_modules/express/lib/router/index.js:280:7
    at Function.process_params (/opt/app-root/src/repo/node_modules/express/lib/router/index.js:330:12)
    at next (/opt/app-root/src/repo/node_modules/express/lib/router/index.js:271:10)
    at /opt/app-root/src/repo/node_modules/express/lib/router/index.js:618:15
Clearly some back-end brokenness occuring here it would seem?
Cisco, are you able to give the ownder of that back-end a poke to let them know they need to check out this system please?
FYI: My reason for needing to access that portal is to complete setup for a CSPC collector VM via following this guide:
https://www.cisco.com/c/dam/en/us/td/docs/net_mgmt/smart_portal/Common_Services_Platform_Collector_Quick_Start_Guide.pdf
Many thanks.
Simon.
1 ACCEPTED SOLUTION
adias
  That is not the correct URL  the correct URL is --->  https://services.cisco.com
2 REPLIES 2
adias
Right-rail
Navigation
Be sure to bookmark these support pages and use them in the future to find all the self-help information.
Helpful Links
