10-11-2020 05:05 AM
Hi.
I am attempting to view https://tools.cisco.com/smartservices/ after logging in with my CCO acount but I am presented with the following when visitng that URL:
Error: Not Found at /opt/app-root/src/repo/server.js:267:26 at layerObj.handle (/opt/app-root/src/repo/node_modules/appdynamics/lib/probes/express-probe.js:164:20) at beforeExecLogic (/opt/app-root/src/repo/node_modules/appdynamics/lib/core/proxy.js:229:31) at returnFunc (/opt/app-root/src/repo/node_modules/appdynamics/lib/core/proxy.js:513:30) at Layer.handle [as handle_request] (/opt/app-root/src/repo/node_modules/express/lib/router/layer.js:95:5) at trim_prefix (/opt/app-root/src/repo/node_modules/express/lib/router/index.js:312:13) at /opt/app-root/src/repo/node_modules/express/lib/router/index.js:280:7 at Function.process_params (/opt/app-root/src/repo/node_modules/express/lib/router/index.js:330:12) at next (/opt/app-root/src/repo/node_modules/express/lib/router/index.js:271:10) at /opt/app-root/src/repo/node_modules/express/lib/router/index.js:618:15
Clearly some back-end brokenness occuring here it would seem?
Cisco, are you able to give the ownder of that back-end a poke to let them know they need to check out this system please?
FYI: My reason for needing to access that portal is to complete setup for a CSPC collector VM via following this guide:
Many thanks.
Simon.
Solved! Go to Solution.
10-11-2020 05:48 AM
10-11-2020 05:48 AM
10-12-2020 10:31 AM
Here is the link to the latest version of the Quick Start Guide.
