05-24-2021 12:50 AM
I only need to give access for updates and synchronization for CSPC collector. Where can I find a list of URLs needed for CSPC collector to work&
Solved! Go to Solution.
05-24-2021 12:55 PM
Ports needs to be verified to be open for specific services added to the CSPC collector in case of SNTC
05-24-2021 10:07 AM
Hi Andrii1,
Hope you are you doing well
We are looking into the issue you posted. We will reach out to you soon with an update.
Thank you
Aishwarya Bhatnagar
05-24-2021 12:44 PM
Hi Andrii1,
Since you need to give access for updates and synchronization for CSPC collector, here is the guide for the reference where you can find the access to be given. Please refer to page 11: https://www.cisco.com/c/dam/en/us/support/docs/cloud-systems-management/common-services-platform-collector-cspc/CSPC-Quick-Start-Guide.pdf
Thank you
Aishwarya Bhatnagar
05-24-2021 12:55 PM
05-25-2021 12:23 AM
Thank you so much!
05-25-2021 12:25 AM
Hi Aibhatna,
Thanks for your answer! In question i mean access to internet (not internal).
